Hey,
I'm new to the forum, and I'm in the market to buy a skidsteer. I'm in contact with a guy a few hours away who has a 2011 226B2 with 2700hrs. Says everything on the machine operates like it should, they replaced the fuel pump and injectors 2 years ago.
Sounds like everything drives appropriately, doesn't pull left or right, but it does over steer with the left joystick. From our messages back and forth it sounds like he turns left (or right) and after you return the joystick back to centre position the machine continues the action for a 1/4-1/2 second. Says in the winter it is much worse, but as the oils heat up it gets better.
Any thoughts?
I've done a few hours of research, seems like the joystick might have some springs, valves and o-rings, that would be sticking or causing some issues... but don't want to jump into a $10K repair. thanks in advance for any help,
-Garrett
Any thoughts?
-Garrett
