RipCon
Evening all,
I have a 2017 Cat 315FL. “Tdy10762” 4000hrs approx.
Started having issues with a E1309 code, (E1389 as well but sounds like that’s just the warning code) coming up that will shut down the machine after it goes into stage 3.
First time it happened I was able to run the after treatment recovery and all was good for approx. 30 hours. After that the code came back. At this point, all removable sensors and def injector, visibly inspected and cleaned. Nothing major. Drained def tank and replaced with new def. After treatment recovery preformed with no issues. Few hours later it was back.
Cat field service came out and could not see anything major, however the Nox sensors may have been acting up, so the updated ones with brackets were installed. Def tank drained again and new def filter installed. After treatment Recovery ran and all good for about 10 hours. Now back to same issue. Any thoughts and what to do next? Waiting for field service to confirm an appointment.
Thanks in advance
Thanks in advance
