Stake out the dam, shoot some elevations and you should be able to calculate the compacted yardage fairly accurately. When I’m calculating a dam I break the profile of it down into various cubes/rectangles and triangles which makes the math easier and more accurate. Don’t forget to include the yardage to put in the core trench. Give us a good yardage estimate and we can nail down your expected time and production a little better.
If this is going to be a one man show a scraper is really the tool for the job (provided you have good dirt). Even something as small as a 5yd pull type scraper behind a decent sized farm tractor would handily out preform a 963 once you start to make longer pushes. Might be able to find and old but serviceable one for $5-7k and sell it when your done, borrow or rent a suitable tractor. Will also provide more compaction than a track loader.
If you are set on using the equipment you have I’d definitely try to find a dump truck you could hire as needed. Wouldn’t need it for all the dirt moving, but would really speed things up as you starting working further from the dam. Load the bucket of your backhoe and use it to wheel roll it in reasonable lifts. That will give you the compaction you need for a project like this, lots of ponds in the past were just pushed up with a dozer and had very little to no compaction in the dam and they held water (usually.) Compacting with any heavy wheeled equipment is fine for a one off job like this, no need to spend money to buy/rent a sheeps foot roller or pad foot compactor.
Good luck with your project and keep the pics and info coming.
Thanks for that! I know most here swear you need a sheep’s foot, but I also know that most people building private dams in this area haven’t used one.. My plan was basically what you outlined - good to hear some agreeance there.
I’ll take a look around for a scraper. It would be easier for me to borrow and get a large tractor here, than it would be the dozer I have in mind. Excellent feedback - I appreciate that.
I drew the dam out in Google Sketchup, and came up with around 7k yards. I’m not worried about the time the keyway will take - I’ll do that with my backhoe, on my own time as time allows leading up to the dam. And the backhoe sips fuel comparatively - it’s a big day if I burn through 10 gallons. My concern is in the dozer / scraper work building the dam, how long that will take me, and how much fuel I’m going to pour into it. Whichever I use won’t be mine, so I’ll be on limited time with it. And I have a limited budget. So yes - an educated estimate on that would help me plan. We’re probably talking a mostly one-man show here, with the occasional friend stopping by to run the hoe while I'm in the dozer / scraper.
Thank you for the in-depth response!
