Hey, my machine is a 2008 with 2700hrs. The left joystick is very slow to react and also overreacts. The right joystick is perfect and works like a charm. Both have very slight external sweating, but nothing I would consider a “leak”
From forward to reverse or reverse to forward, it has a full 1 second pause, which is painful when you need the machine to move. While waiting, the reverse beeper doesn’t come on till the machine starts moving, so I feel like it’s not sending oil pressure to line until it’s moving. Seems like something isn’t bleeding off or returning to neutral quickly enough.
It overreacts when turning left or right, usually by about 8-12” on the bucket. Imagine trying to work close to a car or house. Very annoying.
I've checked oil levels, changed the filter and would like to start testing pressures. I bought a manual online and seems to have all the ports labeled for me, just not sure exactly which ones to test and what numbers to expect.
I should say, it gets worse the higher you rev it, it seems to be worse the hotter the machine, and the reverse beeper operates normally.
Any help is appreciated, thanks!
