Caterpillar 257b3 Turning Issue
Ruben1205
Just bought this used 2012 Cat 257b3 with 4500 hours and it seems to have an issue with turning. It will sometimes turn good and then suddenly either not turn or turn very slowly. Runs forward and backwards just fine. Any ideas?
Between the engine flywheel and the hydraulic pump. There appear to be two schools of thought regarding replacing it. One is to remove the engine and pumps as a unit and split them on the ground (this is the way the manual shows), the other is to pull the pump in the machine and replace it that way.
I’ll leave it to others to comment which method they prefer.
Ruben1205
just a little more info:
- there was already a small leak from somewhere underneath. Not sure where it was coming from. Could it be that air got into the hydraulic system and stopped working?
