CarterKraft
Well if you look at the low drive from a mechanical drivetrain point of view, it is junk and outdated. If it is hydrastat or electric drive then ?
Cross shaft, spur pinions etc are all costly repairs and are not good for production machines. You can have the trans/diff and finals swapped before you can get a old cross shaft drivetrain torn down.
I bet the DPF/ Catalyst for Tier 4 is gonna be a monster, and will require a ton of room to keep it heat shielded etc.
So is the water pump gear driven off of the front gear train or the rear?
Haven't seen a gear drive C9 water pump yet?
