Jason Klassen
More weird things found with the thermal camera today! My brother was watching the main control valve while I pulled one of the track levers. The throttle was in L, I pulled one track lever and had to wait a couple of seconds for the track to try and turn. It tried and then did not move. The engine did load up so it was trying. I held the lever there with the track not moving and the engine loaded. While watching the mcv the hard lines for the bucket and arm variable pressure compensators started to warm up. On the camera you could watch them become more and more yellow while the track lever was held and the track was not moving. After letting the track lever go the lines could be observed cooling down. We waited until they reached the same temperature as the other hard lines which did not take very long. Then we did it again, held the track lever, track stalled, and the lines for the bucket and arm vpcv warmed up.
The bucket was off the ground and the control joysticks were neutral, only the one track lever was being moved. I don't know why compensation for the bucket and the arm would be required? Maybe I should try unplugging the two proportional solenoids that feed those lines?
