macgyver118
I have a Massey Ferguson 50e tractor loader that will not engage in forward or reverse. I have replaced the Vickers solenoid block, and no luck. Fluids are up to correct levels, etc. The pedals cause the relays on the steering column to click, but no solenoid action. I tested current at the solenoid and both of the yellow/red wires, on each side had 12 volts when either of the F/R pedals were pushed??? So I also tested the leads the plug into the solenoids, and both leads on each solenoid have from 4 to 6 volts running to them??? I couldn't find the inline diodes that are in the manual either. It appears the wiring is either shorting out, or something..... Any help would be greatly appreciated.
