didnt know how to adjust angle sensor but i realised the punch mark has to be 180 to the harness! have played around with it quite alot trying it at all positions but not solving the problem but now will do it as youve told me at 4.4 volts with plate in normal position plus will also check the feedback link and get back on that!
the pvc is 1 second off than 1 second on so meaning no fault codes. unfortunately no professionals in kenya so seems im stuck with it and will have to figure it out with help from you guys which is much appreciated. i see there are adjustments on the dp sensor could that be an issue aswell? what do you think is the problem with the boom up it stalls when your using it same time with any other function? thanks
