The Dirt Guy
So my progress has not went well as of now...I had a new pilot pump and pilot relief manifold installed and flushed the hydraulic fluid 7 times. At first the machine seemed to have been fixed, I then took it to a job and it ran like a champ for the first day. The second day functions seem to have slowed back down but was tolerable. The third day my left track stopped but would function when I tried to swing and then it straightened back up and worked normally after about an hour. The fourth day, the track stopped again and i decided to load it up and bring it back to look at. While trying to load, the left track would not function with the pedal but would function with boom up or down. Hauled the machine to the yard and when i went to unload nothing would work hydraulically but you could tell the mahine was trying but nothing stick and swing would barely work. Pump 1 20 mpi Pump 2 less than 10...i had to drag the machine off the low boy. I pulled the filters and the pilot system is full of metal again...and i am assuming my best next step is to just replace both the pilot pump and main pump this time...any thoughts on this?
