Shimmy1
Heh heh... I know Shimmy1Just thought I would give it another mention because I have seen this happen a number of times on different machines in that make, from what the OP is saying I think it could still be the problem.. the easiest way to rule it out is remove the key switch and check it.
Hey man, I was agreeing with ya! These excavators seem to be a bit more complicated nowadays, but my order of operations is: voltmeter at battery, then starter, then have someone turn switch while I'm checking at the start terminal on starter solenoid, if that's dead then it gets a little tougher, have to track back to relays and/or switch, in the meantime jumper wire to start terminal to make sure starter is functional, you all get the point I'm sure. I'll stop rambling now.
