jlittle2212
I would change key switch maybe if you buy key switch they would print you off schematic
Any idea how much a keyswitch would be?
Okay the light bulb just lite on my head Back feed small wire in relay and see if you get power to one wire on key switch
Well, only a schematic is going to tell you that. Have you tried to jump power to the non-ground terminal on the master relay (#8)? Just take some wire and touch one end to battery cable and other end to terminal. Those things usually make enough noise you will know or feel it. If you can get that activated that way, then use the key and try to start.
He said he changed master relay with one he found in his truck, was it any good??????
I have power on the small wire on top of the large battery relay.
So, thank you overworked. Maybe we DON'T know if "new" relay works? I believe he has said in earlier post he has ground at the other??
I do now have dash lights. My problem is I need to know where the two red wires on top of the battery relay goes. I am not getting any power to the top of the battery relay now.
I can take a jumper wire and jump power to the hot on top of the battery relay and can start it with the key. I need a schematic. The local Deere dealer will not print me one off for some reason.:Banghead
Thanks everyone for your input so far!![]()
Back to key switch, 1 power wire hot when key off, turn key to run, not crank, power on how many wires?
If there is a wire that runs to the battery relay, would it be the same color code as in the key switch? Would there be a diode brake between the two?
