Shimmy1
1.** amps at the time when I checked with a meter. Was enough to light the test light though. When you check, double check and triple check things sometimes you tend to confuse yourself. I troubleshot 2 days without a meter, just a test light.
Wouldn't some type of safety shut down prevent power from traveling to the relay as well?
Well, that's what we are trying to figure out, with none of us having a schematic in front if us!! That's why I have been asking if you can determine if the small power terminal (not battery!!) wire on Relay #8 is a direct link to one of the wires under the keyswitch.
