An accurate measurement of a cylinder wall cannot be achieved by measuring the end gap of a piston ring inserted inserted in the bore.
The reason being you don't know what that particular piston ring end gap is in a NEW cylinder with a known inside diameter.
Worn bores have to be measured at the top and bottom to determine if the taper in it is acceptable to put new rings in it.
Many times I had to file piston ring ends to get the correct end gap in new cylinder sleeves.
I noticed in your photo that the ridges in those cylinders hadn't been reamed.
I hope they were removed before you reassembled the engine.
