gkbikers
Hello all.
This is my first post to Heavy Equipment Forums. I'll appreciate any information, advice or help you can offer.
BACKGROUND:
I have searched this site and a number of others, but have not found specific information. However, I KNOW many others have had the same type of problem that I have, which is basically this: I have an old Ford backhoe and the mono-block control valve bank for the 750 model backhoe is dying. It really leaks, the crowd cylinder continues to fall, and the mono-block leaves a puddle on the ground because the mono-block leaks like a kitchen faucet!
I'm sure y'all get the picture. It is an old early 1970s machine, it has not been maintained, it has been abused terribly and then I bought it about a year ago (stupid novice mistake). I've had all the backhoe hoses replaced, new swing chains installed and I had the crowd cylinder rebuilt (thinking it was bypassing - and it may have been) and now the control valves are leaking. Also, various repairmen have worked on it since I have had it and obviously BEFORE I bought it. Hoses have been swapped on the mono-block to try to make it work better, but nothing has helped.
HELP NEEDED:
At this point, I would like to EITHER have the mono-block repaired OR just buy new control valves. The latter is really where I need some detailed information, advice or help. I am not a mechanic, nor am I familiar with hydraulics. However, it is just intuitive that there MUST be a way to put new control valves on this thing. The one thing, above other things, that has me bumfuzzled in that on the swing lever, there is a linkage connected to the control valve (underneath the floor plate your feet sit one) that seems to function to slow the swing at about 75% of its movement either way. I am just guessing. SO, how do I replace the levers and the control valves, etc. on this thing and make it function the way it should? I can live with either a 4 stick arrangement OR 2 stick (like on an excavator) setup.
There, that is my question! THANKS for any help you can give me!!
BACKGROUND:
HELP NEEDED:
