dwall2181
Hello friends,
Can't get the Case 580C to start. New battery and starter. I hear one "click" when I turn the key over but the starter doesn't even attempt to fire. After the first time I try to turn the key over it won't click again until I disconnect and reconnect the battery. But at sometimes there's no click at all when I turn the key over. Is there a solenoid or switch somewhere that can stop power from flowing to the starter? How can I figure this out to get this beast started again? It runs fine once started but as soon as you cut it off you can't turn it over with the ignition.
There's a key and a push button start. The key used to work and I've never been able to get the push button to start it.
Welcome your thoughts on how to fix this.
Thank you in advance
