LMAO, now that I think about it (dig farther in the cob webs of my head) I do believe it was a Telelect Commander digger that I did the boom cylinder.
You probably need to contact Terex for the info you need, the should be able to provide you with an operators manual for sure, schematics might take you a little deeper in customer support. >
http://www.terex.com/utilities/en/
Digger derricks do have some funky operations. Some have a winch or a pole claw at the boom head. The digger itself typically has a fwd/rev lever, but can also have a high speed as well as an interrupt switch to "shake the dirt loose" from the auger. And then there is the system that, when you stow the auger, prevents the operator from putting too much pull pressure on the cable that winds up the auger and stow it in the bracket, thereby breaking the stowing rope.
And most later model diggers have a load sensing system on the boom hoist cylinder. When your using a 3 foot auger with the boom extended, a typical relief valve on the boom hoist cylinder just won't do, you can actually put enough pulling force with that 3 foot auger to bend and damage boom sections, so their fitted with a load sensing system on the boom hoist cylinder to prevent this from happening. ALTEC calls it the HOPI system, Hydraulic Operating Pressure Indicator, can't recall what Telelect uses, but I'm certain it will have a similar system.
