ih100
When did Komatsu stop producing the D21? Never seen one in the UK
As im waiting on some hoses to come in I been checking other ones and even though they look ok from the outside orginal for sure they are just beyond brittle, I had to remove some hose clamps to take one of the cooling hoses from the clutch case and just barely pulling on it to get it up from the frame to pull out it just started falling apart , so if you can afford it and or your duing some repairs I would suggest replacing those hydraulic hoses, just think about it most are under the floor plate and if your running and one breaks or cracks how are you going to know unless it gets so low your blade don't react or a good 1/2 mile from your truck or in a tight spot and you realize something is really wrong. they lasted a good 20 to 25yrs on some of these models so take the time and replace them be cheap now then latter
My d21a-3 doesn't have alot of hoses, it doesn't have the steering ones, basically theres 6 hoses, 2 on each raise/lower cylinder, the pump is hard lined all the way to the front with a short hose off each hardline to pump. I did add 2 more, upon inspection of the blade control stick(valves inside tank) I noticed there was another function, stick side to side. There were also 2 blanked off flanges on the tank. The sideways function had been welded apparently from factory. I cut the welds carefully and moved the lever, and the relief valve hissed. I then removed the blank flanges, and drilled/tapped for 3/8 npt, added 2 hoses with quick couplers. Hooked it to skidsteer woods 7200 backhoe, and it worked. I could use it for a tilt cylinder, but its going to be most likely used for the ripper/rootplow on back. It seems to only really work one way though. I assume it was also for the S(shovel) d21. Another thing different and the -5 and on, is it's a 3 speed power shift, not a 2 speed, 3rd is definitely a transport gear, about 6mph, dont really use it, unworn grousers, it rattles organs around.I'm glad you had a handy hose shop nearby. Those Komatsu dealer prices can get plum ignorant!
The newest one I have ever seen for sale, was a 2008 model, when I was searching on machinery trader, it would bring up 2 d21s (shovel) models in Italy, they still come up.When did Komatsu stop producing the D21? Never seen one in the UK
that guy in NY is real nice and pretty reasonable and he knows a lot about these little machines, Global parts out of Miami is really cheap on prices for hoses but its like 5 weeks before you get anything in shipping from them, The hose are Bridgestone OEM and about 1/3 of the price I just had 2 other ones made today right at 100 bucks if I would have got the other 2 that I ordered made it would be close to 450.00 for themI have a Komatsu d20p-6 we’re is the best place to order parts. Thanks
Morning, finally got almost everything together again but im having issues with the clutch pedal, I got it set up just like the photos in the service manual and have tried adjusting it to where it would come back up but no avail. It shows while engaged pedal up, that the spring is or is right at where it will pull the arm up or down like its right at the point where it can go either way with a nudge. So when you just barey push on the pedal it just gets pulled to the floor, now in the book it sort of mentions this but it never did this before. the only I can get the pedal up is to pull it up by hand. pretty much at lost on where to go from here
I got everything greased up and everything moves really good but I just don't know any help would be greatly appriciated
im in Orange Grove, Tx D20p-6What model is your dozer and where are you located?
Did you seal the bolt holes in the rear of the steering clutch cases?View attachment 219305 my clutch pedal is my only issue now, I got new grouser tracks, rear sprockets, new main clutch and new steering clutches, just drove it a few minutes ago I would say pushing power is over double than what it used to be, and after seeing the old clutch that came out most said that it didn't look all that bad but it was enough that's for sure
