some work pictures
TOM V
CONNECTICUT
Mechanic, Welder, Office work ect.
]RobVG, I had the bucket floor formed with a 1000 TON press brake. That one was 1/2"x42"x48" Hardox 400 and sold it for $650.
The lip was 1 3/4" Hardox 400. The sides were 450 only because I had a drop of 1/2" hanging around. The corner shanks I cut in so the sides were not doing the cutting. Here is the only other pic I have, Thanks for your interest TOM V
RobVG
Seattle WA
17 excavators and a stewpot of other stuff
Very cool Tom. I see how you did the corner shanks now.
Thanks!
TOM V
CONNECTICUT
Here is a 980C that had a pin come out while digging.
RobVG
Seattle WA
So did you apply heat just to the inside of the ears?
TOM V
CONNECTICUT
No Rob I cut out where the steel was cracked and pulled the ear in with a 100 ton center hole ram.
quackattak
Oregon
Tom V,very nice setup you have. Was wondering what the advantage of the dual shield wire is for doing the heavy bucket work. I've done some bucket work over the years and always used 7018 with a sa400. Using the wire interests me, looks like you have a good handle on it. Great pics, hope you have more.
RobVG
Seattle WA
Sorry Tom, I'm used to a rosebud and a 16lb sledge.
hvy 1ton
Lawrence, KS
Good looking work TomV. The truck isn't bad either. Not many people run tandem serivce trucks, but i bet you got that thing packed full of goodies.
TOM V
CONNECTICUT
I have used dual shield wire for over 20 years,it saves a lot of time.
KevD815
Connecticut
Tom, that is some great work! I love your truck too! I run a small side buisness doing the same thing you do...except im working out of an old chevy 2500 with a mid 70's Hobart welder. Total investment of $700 for the truck and welder haha:D I really hope i can step up to a setup like yours someday.
Where are you located Connecticut?
maytag
saraland al
Hydraulic technician in a steel mill
Wire vs stick
Got to love the wire-once you have a good setup for the dual shield there is no comparison. Esab also makes a very good SS wire, Shieldbright-like the Dualshield it runs as good vertical or overhead as it does flat.
Tom, that is a nice rig you have.
Tom
TOM V
CONNECTICUT
Your right maytag the wire is the way to go. Thanks,Tom V
TOM V
CONNECTICUT
Here are a few more pics of line boring a EC280 at the boom base mounting lugs.
ec280 bore.jpgec280 bore 001.jpgec280 bore 002.jpgec280 bore 003.jpgec280 bore 005.jpg
cps
Ireland
plant mechanic
Great job tom, how do you like your york machine? I am thinking of replacing my line boring machine next year, il be giving york a chance to quote!
TOM V
CONNECTICUT
Thanks cps, I like the york just fine, I have had that machine since 1999 and it has been pretty much trouble free. My 1st choice was a climax but it wasn't in my budget at the time, but the york is plenty powerful. What machine are you replacing.
