Tags
The best thing you could do would be to add a temp gauge to transmission and it probably wouldn’t hurt to put an additional external cooler on as well. Heat kills the automatics.
I'm going out on a limb and saying that your in a flat grounded areaThe truck I drive, (1987 IH4900) during harvest has a DT-466 and MT-643 transmission. I'm always just about 70K hauling out of fields to the elevator usually above 80 degrees ambient temperature. Never a problem over the several years I've done this. 12 to 13.5 hour days usually.
View attachment 292767View attachment 292768
Yes, pretty flat here and just corn, or beans. Licensed to 64K but loading from a field they allow a 10% overage without penalty if from field to elevator or storage bins.I'm going out on a limb and saying that your in a flat grounded area
Here in the hills a tri axle dump legal for 73280 guys are crying if they don't have a 550.Yes, pretty flat here and just corn, or beans. Licensed to 64K but loading from a field they allow a 10% overage without penalty if from field to elevator or storage bins.
So when you say driving up hill with the converter unlocked is bad, what about when the transmission is in 1st or 2nd gear? There is no lockup on the MT643 except in 3rd and 4th I believe?Driving up a hill with the converter unlocked is not a good idea.
Some people need to drive a 671 powered class 8 truck in their life before they can drive anything else.
When I ceased driving the old 57 Mack daily in 1999, it still had it's original 170hp "Thermodyne" engine that is non turbocharged and it did just fine for me. It's a truck with manual steering, manual windows, no air conditioning, two stick transmission, and two heaters; the second of which I installed to the left of setting column behind the dash. (alright I'm a puss there but them sonsabitches are cold on the feet in winter and don't have good defrosters).Here in the hills a tri axle dump legal for 73280 guys are crying if they don't have a 550.
Dad always laughs at a tandem dump that the power plants had with a dt466 and a auto that every time it was used needed new transmission fluid because it would cook it.
Just goes to show what is perfectly OK in on place sure isn't good for another
The spare truck has an L10 and Super 10 trans. It does acceptably well also. Nobody really likes that truck citing that transmission needing an overhaul. Syncronizer in rear is very weak. Nothing is fast, nor abused, so works well. Cousin is the owner and all are family that help out. I'm the distant one but get along well.LOL - The 70K gross and DT 466 made me cringe. Our L10 and Allison struggles pulling our D3 on our hills.
The tare on that has to be around 22 to 23K.I'm going out on a limb and saying that your in a flat grounded area
Thanks for the info, and the pic of the MT643 Operating Tips is also very useful.Ok, so mine is a MT643 also to the DT-466. When empty or light, I just put in D and go. When fully loaded I start in 1, and work my way up. When loaded, going up hills I need to use 3 & 2. I watch the RPM's and speed and just go slow. I don't have a temperature gauge. I do in my Kenworth and pick up truck, but this all about slow go and low torque, low rpms. If needed, I can put in the 2-speed low. Truck is licensed at 38,000 GVW. I don't see how its possible to pull 70,0000, he must have a different ratio. I like the truck, but it's not for the highway.
I'll probably be the only driver as none of my help have CDLs, mostly I work by myself anyways. As for the service costs, I figure replacing a few automatic transmissions is cheaper than replacing my knee lol. I'm only 39 but driving nothing but manual transmissions for the past 25+ yrs is starting to take a toll. I want to be proactive so I'm not all hobbled up and worn out in another 25yrs...You might not need a cooler, just will have to see.
With autos v manuals you really have to decide with service and repair cost, which autos are always more (2x). I would guess in your service it probably doesn't matter, might be better off with an auto with all these cheese drivers now days.
I really like them especially with the service I need them for (pulling wells)
I couldn't say how they where driving it at the time he was a mobile maintenance welder who had a cdl and he was learning as he went. They where removing some sorta air sampling stations on top of the mountains around Johnstown about every road they where going up is a hill climb. This all taken place 10 or 15 years before I was a thought so early 80s some timeDriving up a hill with the converter unlocked is not a good idea.
