Washington Iron Works and thier machines
mekanik
Canada's Northwest
This is located in Port Clements
Tugger2
British Columbia
There used to be some shore based Derricks loading log barges up in the Charlottes. Is that grapple from one of them?
camptramp
The warm land on Vancuver Island
Retired Logger Retired Part time pebble hauler
BCFP Renfrew Div. #95 Washington TL15 Trak Loader The #95 TL15 was purchased in the early 1950's . It was built to load with "Tongs" and was capable of short yarding . Sometime around 1970 it was repurposed to be capable of "Grapple Yarding" and some major changes were made to it . The #319 Washington TL 15 was purchased in the mid 1960's , it was used for short yarding and loaded using "tongs" though it was capable of loading with "Grapples". In the late 1960's the "Goose Neck Boom" was shortened a couple of feet and equiped with a wooden "Snorkel" and used for loading with a "Grapple" . In the early 1970's the #319 TL 15 was replaced with a 7220 American set up with a long "Snorkel" for Cherry Picking the road right of way and getting cheap logs off the Yarder Settings . The #319 Tl 15 was put back yarding small corners and settings . eventually the "Goose Neck Boom" was replaced by a straight yarding boom . I always wondered why the #319 was not set up for Grapple Yarding and the #95 was not set up as a Log Loader using Grapples . The #93 Washington TL 15 was a BCFP Pitt Lake machine that ended up at Renfrew Div. (by number it was older than the #95 ) It was set up for loading with a Grapple . It had Main and Opening line brakes on the floor with a knee throttle . It was a nice loader to run . The #319 had a left foot throttle on the floor with Haulback and Mainline brake side by side controlled by the right foot . I always found it awkwscan272.jpg scan273.jpg ard to cover the haulback and mainline brake with one foot .
