alexotoole
so I post a lot on many forums to try to help and educate people in need so hopefully karma can kick some help back here. 1st time poster here and heres what I have going on. 82' bobcat 630 skid steer with a Wisconsin vh4d 4cyl gas engine that only has spark on 2 cylinders. I have replaced with new parts the coil, plugs, wires, ignitor(solid sate electrical ignition) cap and rotor with all oem quality parts. I even exchanged the coil to be safe with another new one to no luck. cylinders 2 and 4 have spark(right bank), 1 and 3 (left bank) none. I'm getting 11 + volts to coil but spark from coil seems like it once every .5 seconds not constant(not sure if it should be). I have re-grounded a new engine and chassis ground. In timing it with a gun, its spot on what should be #1 cylinder but I cant tell cuz it has no spark but btdc is spot on where marks on case align. I pulled the distributor and swapped it 180 degrees and it runs the same after switching dist wires around but runs on cylinder 1 and 3 (left bank). I tried to unplug regulator and rectifier one at a time while running to no gain. took apart dist to clean and inspect and see nothing out of the ordinary. I also swapped wires plugs etc with the working side to rule that out to no success as well. I even hooked up a charged jump pack to the positive side of the coil + and negative to chassis ground to see if the coil would fire different with higher voltage and nothing changed. one thing I can say is I pulled the monster flywheel off and the magneto or magnets inside were filthy one of which was shattered (maybe 8 or 10 total inside) and the stator filthy as well, cleaned them with wire wheel and still no luck. would the stator affect this? I always thought if you unplug it with a charged battery it would spark regardless. Again any help much appreciated as I'm in this with way too much time and money. sorry for the paragraph lol.
