PaulMckee
I have a Case 580c backhoe. I replaced the brake master cylinders, which required the removal of the dash console that required removal of the shuttle and throttle levers/assmbly. After reassembling the console and shuttle/throttle levers and beginning to test my brakes, I noticed that the throttle lever was loose and not staying set. Of course this caused the machine to die without either holding the throttle lever in place or keeping the foot petal pressed enough. I have surfed the web and this forum over several times and not able to find any help on this. And I’ve searched the Operators/Service manuals without any discovery. There must be something that keeps resistance on the throttle lever, but I’m not seeing it anywhere in the linkage. And this was working fine before I removed/disassembled the console/shuttle/throttle to do the master cylinder replacement, so I’ve introduced the problem somewhere. Your expertise is welcome. Thanks!
