Case 580c throttle lever not staying set
PaulMckee
Fort Worth, TX
I have a Case 580c backhoe. I replaced the brake master cylinders, which required the removal of the dash console that required removal of the shuttle and throttle levers/assmbly. After reassembling the console and shuttle/throttle levers and beginning to test my brakes, I noticed that the throttle lever was loose and not staying set. Of course this caused the machine to die without either holding the throttle lever in place or keeping the foot petal pressed enough. I have surfed the web and this forum over several times and not able to find any help on this. And I’ve searched the Operators/Service manuals without any discovery. There must be something that keeps resistance on the throttle lever, but I’m not seeing it anywhere in the linkage. And this was working fine before I removed/disassembled the console/shuttle/throttle to do the master cylinder replacement, so I’ve introduced the problem somewhere. Your expertise is welcome. Thanks!
Coy Lancaster
Arkansas
service tech
Tighten nut #6 to put tension on disc #5 that is what holds the throttle lever in place.
PaulMckee
Fort Worth, TX
Thanks Coy! Seeing and hearing your description is bringing back some memory during disassembly. :/) That console is a bear to navigate. Any best practices for accessing that area? Can it be reached by removing the instrument cluster? Thanks again.
Oh, I'm also curious where you located that diagram... service manual? It's resolution is too small for me to see the finer details and reference numbers. Thanks.
redranch
Mt
If you ever have to take the master out again this is how i did it when i had a C. Take a hole saw and drill a hole on the side of the console across from the master. You can remove it that way, then just plug the hole for next time. Saves a lot with out taking out the console.
PaulMckee
Fort Worth, TX
Thanks all. I'm not able to get access through the cluster hole. Still a bit baffled how I disassembled this coming off. But at least the problem is identified... just a matter of access.
PaulMckee
Fort Worth, TX
Good idea @redranch In hindsight, for sure the better idea. It was a beast.
I did finally get the throttle resistance mechanism reconnected. And in doing so, understood why I didn’t remember disassembly… because I didn’t. When I removed the throttle lever, it popped free. I remember hearing a pop, but not knowing what it was.
My rpm gauge is no longer working and is pegged out on the high side. Curious now about what may have happened there. I’ll search and post accordingly on that topic.
Thanks again all for comments and this community for willingness to share knowledge and experiences.
AGoebel
Ames, IA
Paul,
How did you get throttle tension hooked back up. Going through same thing. Any help would be appreciated, thanks.
Coy Lancaster
Arkansas
service tech
Cody, this spiderman have same problem but how the throttle level to #9 connected does not show how they connected or what with
There is a roll pin that engages item #9 and the tightness of item #4 determines the tension of the hand throttle.
Spiderman74
Thanks that's must be the problem because there nothing connecting the two roll pin must have fallen out this backhoe have been sitting up for few year got back together wanted try backhoe out but couldn't figure out how to get throttle to stay
raypan
Massachusetts
i am replacng master cylinders on my C and there are access holes cut on the side of the dash.I dont think it's enough room to remove brake lines easily, so I am taking the dash off. It is entirely free except for some cable that the manual says is for ether to be injected for a cold start???? I will look to see if I can disconnect it from the engine side becasue the cable does not separate. Also, removing the dash was a nightmare because I had a windshield wiper motor sitting on top of it that was a pain to remove,all the wiring, the throttle lever, the shift lever, it was not fun but if doing both MC's, i figured I might as well give myself as much room as possible.i am also doing both slaves so the floor will come out too. THAT is also a nightmare because I have a heater that has radiator hoses coming up through the floor that have to be disconnected.Luckily i have amonth or so becore I will use the machine,,,
Kurly
Retired
I
I cut slots in the floor to allow the radiator hoses to remain connected, worked great. I also drilled (with hole saw) 2 holes in the left side of the dash to allow the master cylinder bolts to be removed, easy to replace Master Cylinders.
raypan
Massachusetts
I
cutting slots sounds like a great idea. The hoses are the biggest pain because of coolant loss,,everything got put on hold for a few days because the 2 masters were 1/8" wider than the original ones so they did not fit. Vendor is sending out a new set but im thinking those will be the same. I might have to shave down the center bracket to make them fit.
stinky64
java center ny
Hose clamping pliers or small needle nose vise grips installed underneath the floor pan close to the heater will minimize coolant loss. You can then pull hoses from heater then floor pan if really needed. Just be careful when removing hoses from heater pipes, may be corroded or brittle, she ain't no spring chicken.
