The diameter of pipe does not affect the pressure the height of water creates
Learned that when I worked for a irrigation company for short time.
Is there a hidden/ghost gear in a 13spd?
Because Ben Franklyn considered it to be an invisible fluid flowing from a place of excess (+) to a place of deficit(-). He arbitrarily guessed & assigned - (negative) to electrons. He later figured out they flow the other direction & only partially corrected his earlier presumptions.Another thing a lot of people get wrong is which direction direct current electricity travels. Many people think positive to negative but it's wrong. It flows negative to positive. In welding it makes a lot of difference and is critical which way it's flowing in a lot of applications.
231 inches depth is 1 gallon in a per square inch sense.1 gallon weighs about 8.4 LBS I'll say 231 inches deep will give 8.4 psi. When I calculate the elevation difference between my water supply, that about works out in the middle of the night when usage is low. May I read your comma as a decimal point? Then we agree.If you have a pipe 10 ft tall 1ft diameter filled with water and a pipe 10 ft tall 10 ft diameter filled with water, with a pressure gage at the bottom what PSI will the gauges read ?
27,68 inches of water will create 1 psi so each pipes pressure gage will read the same about 4. 33 psi. Think of diving in the ocean if you are 10 feet deep about 4.33 psi on you same as if you are 10 ft doen in a pool. The diameter of pipe does not affect the pressure the height of water creates
Its been awhile, but I remember using the retarder to help break in an overhauled 3406, so I'd say the jakes will come on first if selected, retarder is manually applied?, I forget how to do it though. That was back in about 1990 or so?On a Cat engine with retarder and jakes-which one is applied first?
Yes was meant to be decimal point 231" / 27.68 " = 8.34 psi231 inches depth is 1 gallon in a per square inch sense.1 gallon weighs about 8.4 LBS I'll say 231 inches deep will give 8.4 psi. When I calculate the elevation difference between my water supply, that about works out in the middle of the night when usage is low. May I read your comma as a decimal point? Then we agree.
Is it possible to split the bottom gears in an unaltered 13 speed?Is there a hidden/ghost gear in a 13spd?
Nope-it takes a 18 spd back section and axillary drive gear.Is it possible to split the bottom gears in an unaltered 13 speed?
The hidden gear was once in fifth direct flip it to overdrive and shift to low not first. This was done to keep from
dropping to 4th under. The ratio works out slightly higher than 4th, but it must be done smoothly. Eaton
does not recommend it. And really your not gaining anything.
I know that's the proper way but it is actually possible to split the low range gears in a 13 speed with a 13 speed
Well never used to have a tree falling wind storm in the area every 2 weeks or so maybe every 3 or 4 years. Never had 112 degree days in this state. Never had a summer and extended summer with no rain and 80 plus temps with no wind for 4 plus months. All with in the last 2 years. And goes along with many other things like food plant fires and dead cattle and chickens. I'm not an anti mineral fuel person. There is a reason for this weather and if was known it would ruin the fun of some.Weather is always crazy. We just pay attention to it more because the media is conditioning us to. Weather patterns have been a moving target since they started keeping records only 200? Years ago.
Flip the range selector up and then put it in the high split. As long as the shift lever doesn't touch neutral it shouldn't complete the range shift.You would be the only one on the plant I know of that can.
