microwave
I have a 1952 payloader with payloader stamped on the counterweight with the 4 cylinder waukesha engine 3 1/4 by 2 The engine was stuck when I got it. I put penatrating oil down the cylinders and took off the side plates and squirted penetrating oil on the valve stems. In 2 days I was able to turn the engine over and get a stuck valve to release.I'm going to look at a HA tomorrow-stuck engine, starter in basket w/missing parts, but new hydraulics. Someone started fooling with it and quit. Equipment dealer only wants $600 for it. I gotta look for that price...
If you had success with your HA, I'd like to hear about it.
C>
After cleaning the points and rebuilding the starter the motor started and ran. After about 10 minutes it stopped smoking and smoothed out to a steady rythem of 4 cylinders running smoothly.The water pump leaked and I repaired the seals with epoxy as the bearings were still tight.
The hydraulics were good as the main cylinders looked like they had new seals and they did not leak.
As demand for the fork lift someone put on it in place of the bucket is not high I am considering selling the machine. It has 4 speed tranny with foward and reverse stick. My phone # is 870 322 c7099 and my name is Joe
